Advise on Becker 7990 with my W210 1998...
Cheers people,
I am very interested to get the Becker 7990 http://www.mybecker.com/beckerCms/ww...003&navSeq=224
for my Mercedes W210; However I have some questions:
Will this fit my car?
If it will; will it fit as plug and play or not?
Thanks.
Thanks.
anyone?
You can download the manual at the same site to view the DINS connectors.
Here is the manual: http://www.mybecker.com/beckerCms/ww...tion_Guide.pdf
Here is an images:
Here is an images:
Just for the update of the subject and for sake of others seeking the same question to be answered; I got a confirmation from Becker that the unit will work on my car without any cable modifications as it turned out that my factory Mercedes player is a Becker BE2210, here is the response:
"Pinning of socket A (supply voltages and special functions) is pin compatible. Socket B (loudspeaker) is compatible as well.
But only socket C is not compatible neither in connector dimension nor in function.
Consequently the BE 7990 can be installed by using the existing and present connector of the car (A+B)
with kind regards
i.A.
Roger Hertel
Harman/Becker Automotive Systems GmbH
Quality Customer Service (QCI)
Tel. +49 7248 71-1210
Fax +49 7248 71-1246"
with kind regards
i.A.
Roger Hertel
