Command and Cd Questions (w211)
i just got a couple questions about the command. i wanted to know what the WAP was and how does it work. i tried playing with it and there was a place for me to put a URL in but i dont know where to connected with. do i need to get the phone. and about my cd changer, my uncle and I installed it and everything was fine. it was working alright and then it switched tracks and the sound went crazy. its a scratchey sound and just isnt right. i checked to see if it was my speaker (thats kinda what the sound sounds like blown speaker) but the radio and indash cd player was working fine. no i dont if its the cd changer or the wire or what. i just got the fiberoptic cable from the dealer and i dont know whats wrong any ideas. oh and i took apart the system again and unplugged everything and plugged it back up but it did the same thing. i got the cd changer from mbdoctor too.
Did you have the MOST setup coded at the dealer? I have not had new equipment added to a MOST based car but it should need a MOST configuration coding by DAS.
WAP is wireless application protocol, a simplified version of WWW browsing, invented for early mobile applications that were not able to support full WWW. You would need a GPRS capable phone. I'm not sure if the WAP access point would need to be programmed on the phone or if that is programmable from your Comand, I assume it is using the default access point on the phone. Should figure out if your carrier supports WAP, they did but I'm not sure if US GSM operators do that still today (don't know about my operator, have been using direct internet access and full www so long). Some operators do not allow direct internet access but only access through their WAP gateways, to control services and charging of course (crippled service). Then you could start "web browsing" from your operator's home page, to be sure the url is allowed and supported.
i dont know what MOST is but no i didnt have it coded. i disconnected the unit but ill check the fibre connectors again though. thanks Diesel Benz
Therefore if you at a new multimedia device to you car, the device must be add to the most ring so it will know that device is available.
just like when you add a USB device to a computer which don't have the drives pre installed. the computer will not communicate with the device even though its physical connected, the computer don't know what to do with it.
