Sponsored by: Innova
Adding BT to 05 c320c
Old Oct 22, 2007 | 12:53 PM
casolorz's Avatar
c320c
Question Adding BT to 05 c320c
I read the bluetooth sticky but didn't find (probably missed it) instructions on how to add BT to an 05 c320 coupe. I think the car is not prewired for phone because I don't see anything on the armrest where I could plug in the wireless4mb bluetooth puck.
So I am guessing I will first have to do all that wiring?
Are there cheaper alternatives? what parts can I do myself? what do you call all the wiring that has to be done prior to the putting in the bluetooth puck?
Thanks,
--Carlos
Old Oct 30, 2007 | 11:55 AM
tzar007's Avatar
E500 4matic
I am in exact same situation. I have 2005 E500 4matic.
I would like to install BT but I was told in the dealership that pre-wiring was not done on my car. They were asking $1000+ for the whole thing.
I also don't see any wires/plugs in the central armrest compartment.
I read that ALL 2005+ were pre-wired? Is that true?
Thanks,
Old Oct 30, 2007 | 12:00 PM
casolorz's Avatar
c320c
Thanks,
I think they were prewired all the way to the armrest, meaning you won't have to go back to the trunk and modify things but you will still need to get the plate insert, but what I am trying to figure out is what else is needed because I see people doing all sorts of weird hookups that involve antennas and what not but I don't see why that is needed for bluetooth.
Old Oct 30, 2007 | 12:19 PM
Diesel Benz's Avatar
You don't either see a plastic cap at the armrest storage space, one that protects the MHI connector and clips off?
Old Oct 30, 2007 | 03:46 PM
tzar007's Avatar
E500 4matic
Nope, none of that. I'll take a picture later and post it. Just to make sure I'm not missing something.
Old Oct 30, 2007 | 03:59 PM
If the floor in the storage compartment does not have a connector, lift up the false floor and see if you have the antenna and the cradle connector there.
And the same as always, if you post or PM your VIN, one can find from the vehicle data card if it is prewired.
Old Oct 30, 2007 | 04:09 PM
casolorz's Avatar
c320c
I know u were asking him but here is my data card info I think:
Plant 50
Model C 320
Chassis 2037641A727358
Engine 112946 31 915880
Transmission 722618 05 655483
Tyres
Primary MICHELIN
Order 0 5 704 04224
Delivery date 24.09.04
Dealer United States (USA) (704)
Interior Unknown code (121)
Paint
723 cubanite silver metallic
Options
FCL compact limousine (с 29.03.1996)
M32 capacity 3,2 liter (с 02.10.1995)
232 Unknown code
249 automatically dipping inside rear view mirror (с 01.06.1990)
264 shifting gate for automatic transmission (с 01.01.1996)
275 front seat positioned lower
memory package (driver's seat, steering column, mirror) (с 01.10.1993)
287 ski inboard loading facility
through-loading feature (с 01.10.1990)
293 trunk set, 3-piece
sidebag in rear left and right (с 01.01.1995)
30N Unknown code
301 storage box in the rear (с 01.05.1988)
309 cupholder (с 01.06.1995)
345 rains sensor for windshield wipers (с 01.10.1993)
387 Unknown code
413 Unknown code
423 5 speed automatic transmission / nag (с 01.03.1994)
461 instrument with mileage reading and english lettering (с 01.04.1990)
494 California version
version for USA/California/Canada (с 01.01.1996)
524 paintcoat preservation (с 01.01.1964)
531 automatic antenna (с 01.01.1963)
535 Unknown code
551 anti-theft/anti-break-in warning system with anti-towing system (с 01.04.1998)
573 front seats, left and right, with seat height adjustment
580 air conditioner/Tempmatic (с 01.11.1982)
634 elimination of first aid box (с 01.08.1977)
636 elimination of warning triangle (с 01.03.1973)
668
669 spare wheel (с 01.06.1995)
spare wheel (R170)
673 high-capacity battery (с 01.01.1964)
763 Unknown code
805 Change of year of model, last figure shows new model year
810 loudspeaker, sound package
sound package (bose) (с 01.12.1986)
819 CD changer - alpine - in trunk (с 31.07.1992)
875 heated screen wash system (с 01.02.1988)
windshield washer heated (W201)
929 Unknown code
949 equipment package mk-line (с 12.06.1997)
986 identification plate (vin no.) (с 01.07.1992)
989 identification label under windshield (с 01.10.1997)
Old Oct 31, 2007 | 02:56 PM
tzar007's Avatar
E500 4matic
Hi, this is my data card. I don't see any "pre-wiring" options.
I guess it means it has not been pre-wired unless N28 or 28N below means something to somebody
M50 DISPLACEMENT 5.0 LITER
N28 STEUERCODE WERK SINDELFINGEN/GRAZ
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING
242 FRONT SEAT RH ELECTRIC ADJUSTABLE WITH MEMORY
264 LICENSE PLATE ATTACHMENT AMERICA
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
297 SUN BLIND IN REAR DOORS LH AND RH
309 CUPHOLDER
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
443 HEATED STEERING WHEEL
489 AIRMATIC DUAL CONTROL / AIR SUSPENSION SEMI-ACTIVE
524 PAINTWORK - PRESERVATION
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
581 AUTOMATIC CLIMATE CONTROL
615 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
636 DELETION - WARNING TRIANGLE
673 HIGH-CAPACITY BATTERY
763 RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
810 SOUND SYSTEM
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
910 DYNAMO WITH HIGHER CAPACITY (FFO)
919 AIRCON COOLING POWER PACKAGE
986 IDENTIFICATION NUMBER (VIN-NO.)
830A AMARETTA/LEATHER/NAPPA/SEMI-ANILINE
221B SIGN COOLANT/REFUELING - ENGLISH
7XXL NORTH AND SOUTH AMERICA
744U BRILLIANT SILVER METALLIC
N23 STEUERCODE WERK SINDELFINGEN/GRAZ
R11 LA 17" 5 DOUBLE SPOKE DESIGN
232 GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
265 LINES-NO.PLATE DISCONTINUED
28N STEUERCODE WERK SINDELFINGEN/GRAZ
293 SIDEBAG IN REAR LEFT AND RIGHT
301 ASHTRAY PACKAGE
359 LOW COST TELEAID USA
423 5-SPEED AUTOMATIC TRANSMISSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
494 U.S. VERSION
530 COMAND DVD APS USA WITH NAVIGATION
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
600 HEADLAMPS - CLEANING EQUIPMENT
634 DELETION - FIRST AID KIT
668 PACKAGING FOR SHIPPING VEHICLES W/ TIE-DOWN HOOKS
690 EMERGENCY SPARE TIRE (MINI SPARE)
805 YEAR OF MODIFICATION
819 CD CHANGER
875 HEATED SCREEN WASH SYSTEM
915 FUEL TANK WITH LARGER CAPACITY
955 EQUIPMENT PACKAGE ELEGANCE
989 IDENTIFICATION LABEL UNDER WINDSHIELD
212B OWNERS MANUAL AND SERVICE RECORD - AMERICAN
284B AIRBAG SIGN - AMERICAN
704L UNITED STATES (USA)
831A AMARETTA/LEATHER/NAPPA/SEMI-ANILINE - BLACK/ANTH.
Old Oct 31, 2007 | 03:17 PM
tzar007's Avatar
E500 4matic
Here is the pic of my central armrest. No connectors.
Old Oct 31, 2007 | 04:23 PM
387 equals to "mobile preinstallation, USA/Canada".
Old Oct 31, 2007 | 05:41 PM
tzar007's Avatar
E500 4matic
I guess, I'm s***t out of luck then .
What would be realistic price to pay to install everything, wiring and BT in a dealership? I just want to be sure my dealership is not overcharging me.
Thanks,
tzar
Old Oct 31, 2007 | 07:58 PM
casolorz's Avatar
c320c
so i am guessing that means we have it? Can i just buy the bluetooth adapter then?
Old Oct 31, 2007 | 08:06 PM
Kimber's Avatar
2005, E500 Designo
There is another thread on the installationof the Blue tooth adapter I believe it is in the W211 forum as I understand on the W211 you first have to remove the plastic cover in the glove box where the two buttons for Tele Aid are. Than there is supposed to be a connector you pull thru.
BUUUUUUT, prewired does not mean the "equipment is there" for transmission and reception, you just don't have to run the wires. on the W211 I thought the 2004 can be just hooked up because the Tele Aid is connected to the phone aspect. Buuut again the I understand the "equipment" is not digital. So it will not work when the change to all Digital system is made.
Old Oct 31, 2007 | 10:46 PM
lkchris's Avatar
'10 CL550, '12 GL550
http://home.earthlink.net/~phdwebsit..._bulletins.htm
Old Nov 1, 2007 | 02:49 AM
I guess you are talking about the "puck with tail" option. A useful reminder. I'm not familiar with this but it should be for US cars with Tele-aid. Likely the way to go if the car is not pre-wired (or would it still have to be prewired?).
