Dietz multimedia adapter COMAND 2.5
thanks
" Connect the red, loose wire from 1441 with terminal 30 (permanent +12V), and the black, loose wire with
chassis ground negative"
http://www.dietz.biz/dokumente/1441_D-E%20SW1.2.3.pdf
__________________
Not sure about the Comand unit but I assume you would have the same A-connector: pin 4 should be constant +12V.
http://www.buellwinkle.com/Comand/CO...oval%20WIS.pdf
