Problem with install navigation DVD 2006.1
Mercedes E240 4matic 2004
First of all congratulations for yours site.
I have a Mercedes e class 240 4matic (2004)
From the factory the car it had the navigation (comand dvd APS) but the dvd that it had did not have Greece maps
So i took from ebay this dvd 2006.1
other I saw afterwards that it does not make for my car.
I try to install it
I put in driver in back and it began this it makes install
However does not make nothing and says constantly
navigation activated - please wait...
Today i remove dvd from behind and I put the first dvd that had from the beginning the car.
However in the screen says :
no dvd
Please insert navigation dvd
(boot)
what it should I make so that it takes the initial dvd ???
Regards...
I try to install it
no dvd
(boot)
Regards...
2005 S500 4-Matic, 1978 450SL
I hope your car is still under warranty. The first thing a new DVD does is install a firmware update. If the update was not one intended for your car's nav system, you may have damaged your nav system's firmware. The dealer may have to re-flash the firmware.
I suggest that if the car is under warranty you may not want to go into detail about how this happened.
You should order your updated disc from a reliable Mercedes source.
