Sponsored by: Innova
Unplugged CD Changer?
Old Nov 7, 2002 | 04:34 PM
getchellad's Avatar
02 C320 S.E., 02 BMW 330XI, 00 4Runner
Question Unplugged CD Changer?
Would Unplugging the two wires that connect to my CD changer in the glovebox have any effect on the the speakers not working?
Thanks,
Adam
Old Nov 7, 2002 | 05:07 PM
Lynn's Avatar
It shouldn't have any effect on the speakers. You should still be able to hear the radio.
rskinner's Avatar
2001 C240/2000 ML320
Not sure, can you plug them back in and check?
Old Nov 7, 2002 | 05:10 PM
Buellwinkle's Avatar
Suprisingly if the fiber loop gets interrupted it can have all sorts of ill effects. My radio would turn it self off an on every 20 seconds because of a faulty fiber cable. I think if you remove it you have to put in a plug to terminate it.
Old Nov 7, 2002 | 07:43 PM
getchellad's Avatar
I've been trying to troubleshoot my radio. See all my other posts.... unfortunately, my CD player is currently in Ohio, and I'm in NY. I thought it would have no effect upon the radio by having the CD player unplugged, because the fiber optic that plugs into the CD player comes practically plug and play ready. I'll pick the CD player up this weekend, and see if it fixes the problem.
Thanks Guys,
Adam
Old Nov 7, 2002 | 07:57 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
i know this has been discussed before but my cd player gets staticy everyday then shuts, if it is a faulty fiber optic cable will the dealer replace it?
Old Nov 8, 2002 | 06:26 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Re: Unplugged CD Changer?
Thanks,
Adam
I believe that if your car came with a fibre optic changer, the headunit is programmed to recognize it. if it is unplugged, the headunit software may continue trying to look for it, making it inoperable until changer is reconnected.
u might have to get the stereo reprogrammed if you want to keep the changer disconnected.
check with your service advisor, that is the safest bet(sometimes)
Old Nov 23, 2002 | 05:38 PM
Cryptnotic's Avatar
Those wires provide power to the CD changer (you can't send enough power over the fiber optic cable). If there is no power to the CD changer, the changer won't be able to transmit on the fiber optic cable. So it is essentially the same as a break in the fiber optic link. Now, if you have the Bose system, that would cause a problem since supposedly the Bose amplifier is hooked up to the fiber optic network for the audio signals. So the Bose might not get the audio from the head unit.
If you don't have the Bose though, it would be just like disconnecting the CD changer.
