Mercedes IR receiver location?
Does anyone know the location of the factory IR receiver brain?
Please and thank you
Anyway, driver authorisation IR signalling occurs between the key and the IR receiver at the key slot. EIS along with other elements would make DAS and once the authorisation system accepts the key, it allows it to turn in the slot.
Perhaps some posts on EIS could provide more info.
To answer your question, the EIS (key cylinder is the actual receiver for the IR signal. It is then transmitted to the ECU to verify the code.
