rear speakers not working... could it be a fuse or is it my amp? (bose, slk230)
any help here would be great... I have a becker cd player with a bose speaker set up and my rear speakers are not working (MB upgrade option 1998 SLK 230, no CD changer in trunk)-- problem started after putting in a new battery if that means anything... I first thought perhaps the deck was the problem, because I had to pull it to get the serial # to get the code (thought maybe I loosed a connection inside the deck) -- but then I saw that the outputs on the deck were only connected for the front speakers (I assume the amp splits the signal for all the speakers)... SO -- Does anyone know if this could be a blown fuse somewhere or does my amp have a blown channel??? any info would be great here, for instance, is there a separate amp or fuse for the rear speakers?
Eric
