Sponsored by: Innova
How do I remove a comand center?
Old Mar 19, 2008 | 10:57 AM
pjwoude's Avatar
ML 320 CDI, C180
W164 ML320, I need to replace the comand center. How do I pop out the existing one? Do I need any special tools? TIA pj
Old Mar 19, 2008 | 03:50 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
See www.mercupgrades.com select W164 ML, and your country and search for documents - theres a document on taking it out there. Just need a torx driver and know how to dismantle it
R
Old Mar 19, 2008 | 07:15 PM
am_beagle's Avatar
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
Talking Removal COMAND head
http://www.mercupgrades.com/Removing...rticle-21.html
Good luck.
Old Mar 19, 2008 | 08:37 PM
am_beagle's Avatar
Cool Move to Europe
Ifif you are bringing a North American MBs to Europe (etc) then this article is useful as you will have to install a European COMAND APS system if you want European maps for navigation.
http://www.mercupgrades.com/COMAND+A...rticle-39.html
Old Mar 30, 2008 | 12:16 PM
pjwoude's Avatar
ML 320 CDI, C180
Thank you
Old Mar 30, 2008 | 05:06 PM
pjwoude's Avatar
ML 320 CDI, C180
I tried to follow these instructions. However, my car appears to be somewhat different. I removed the ashtray (removed two trax20 screws) but I couldn't locate the lever to remove the front panel (and the comand center).
PJ
Old Mar 30, 2008 | 05:15 PM
Richard's Avatar
The screws you should have removed go through the slide bars that hold the comand unit in place.
1stly, remove the panel below comand (see picture in article)
Then remove screws holding silver levers and slide them downwards - then slide out the comand unit !
Cheers
Richard
Old Apr 3, 2008 | 10:07 PM
am_beagle's Avatar
Question
Cheers
Richard
Ric,
Is it a plug-and-play love story between US and Euro Comand ? Is the radio code needed after replacing the HU ?
Old Apr 4, 2008 | 04:51 AM
Richard's Avatar
Radio will need coding to understand the fibre network in the car
Possibly the cluster as-well
And if you want a US cluster to display KM/H and be in imperial not US gallons, and switchable between KM/H and MPH (limited to 160KMH on the analog speedo as thats where the numbers go, if you have a cluster that is capable of being switched (not all)) then you need someone who understands factory mode on Star Diagnosis - which the dealers do not.
PM me if you want a suggestion of someone, but they are in limited places..
Richard
