Sponsored by: Innova
Ordered my V1!
Old Apr 30, 2008 | 05:59 PM
Solidjake's Avatar
02 330i & 99 ML430
Ordered my V1!
YES!!
Old Apr 30, 2008 | 06:42 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
I did a bit of research on this after getting a LIDAR ticket a few months ago. I currently have an Escort 9500i (their flagship) that supposedly has laser detection. I can tell you that unless you are lucky enough that the cop aims the laser right at your detector, even then you will only get an alert that basically tells you "you just got busted"! If your goal is to beat laser, detection won't do you any good. You must have an active jamming system. After researching this, I found the only consistantly successful system out there is the Escort "Shifter ZR3" It goes for about $350 and requires some installation time. You basically need to mount two transmitters/detectors in the front bumper (and run wires to them) and one transmitter/detector in the rear bumper. Almost always the cops will aim the LIDAR gun at your front or rear license plate area. This is why you place them there. The Shifter ZR3 is called "Shifter" only because Escort thinks the word "jammer" is a bit politically incorrect! But it is a very good jammer. This unit also will integrate with any existing Escort radar detector nicely.
I've heard good things about the Valentine unit, but if you want to be fully protected (don't speed! ) you need laser counter-measures. Here in CA I'm seeing the laser (LIDAR) being used more and more. It got me about 3 months ago and the radar/laser detector never made a sound. The 9500i has worked awesome though so far for conventional radar (almost all Ka band in CA),
Hope this info helps for some of the folks out there.
Old Apr 30, 2008 | 07:19 PM
Solidjake's Avatar
02 330i & 99 ML430
^^^ I know all of that. Anyways, I have a PBA card, SBA very very soon, I also have a list of every spot where they use laser in the places where I drive.
Old Apr 30, 2008 | 07:34 PM
D Bst's Avatar
2004 E55 AMG; 1995 Porsche 993 Cab.
Be careful running Laser "shifters" in CA. They are no-no's and will get you an even stiffer penalty if you're found using one...
Just an FYI.. DMV VC 28150
http://www.dmv.ca.gov/pubs/vctop/d12/vc28150.htm
Old Apr 30, 2008 | 08:01 PM
Solidjake's Avatar
02 330i & 99 ML430
Originally Posted by D Bst
Be careful running Laser "shifters" on CA. They are no-no's and will get you an even stiffer penalty if you're found using one...
I live in NYC...
Old May 1, 2008 | 07:44 AM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
YOu my friend are fooling yourself. Unless you're driving one of the new highway patrols chargers you're gonna get nailed - been there done that despite multiple cards. Get an active system - also realize there is no plea bargining in NYC for speeding tickets
