How can I get more power out of my stock system?
is there a way to achieve this without changing the speakers?
I wanted to know if I can just replace the amp?
I currently have the 320 watt harmon kardon logic 7 in my 08 clk
I want to have at least 450-500 watts
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Without cooking the speakers? Probably not. You are also going to be hard pressed to find a 450-500 watt amp with MOST fiber inputs that will connect to your head, which means going the route of using something like a JBL clean-sweep to give you line-level inputs for your new amp from your old one.
so what do you think is the max wattage I can get out of my stock speakers
I know the new C Class has like 430 watts but im not sure if they are the same speakers as mine
