Sponsored by: Innova
Blue Tooth V60 Help
Old Feb 10, 2009 | 11:26 PM
vmaddon's Avatar
2002 CLK55 Conv
Blue Tooth V60 Help
I have an 02 CLK55 with Command 2.0 and the Autosense PSE 0754 9266A.
From what I can determine, all equipment was factory installed and all options are present, including tele-aid, voice command, ...
I purchased a BMW V60 puck CPT9000, from an owner who successfully used it in an 04 E55.
My phone, and my wifes, pair fine.
On the command, I see Error: Tel. not plugged in.
I have read up as much as I could prior to asking here, but I am a bit stumped.
Does this sound like a coding issue or should I look elsewhere???
Any assistance would be very much appreciated.
Thank You
Vince
Old Feb 11, 2009 | 08:46 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
The '04 E-Class used a very different PSE than yours. There is no guarantee that a BMW puck that worked in an '04 E-Class will work with an Autosense PSE in a '02.
I suggest that you try an MB V60 puck (borrow one if you can, before you buy).
Old Feb 12, 2009 | 11:30 PM
vmaddon's Avatar
2002 CLK55 Conv
After doing some additional research, I stumbled accross a very knowledgeable gentlemen on ebay, cellguy85.
At a point where my problem had little commercial benefit to himself, he still provided me additional info.
SNIP>>>>>>
That BMW Puck is the problem..It will not work on D2B fiber optics like your '02 CLK..That '04 is 1st gen MOST and would work..No more digging needed,you need MBZ #B6787-5856...Funny thing is that the BMW & MBZ V60 phones interchange..
SNIP>>>>>>
Anyway, thanks to all who replied and thanks to cellguy85.
You should keep him in mind if buying these items on ebay.
Vince
