Sponsored by: Innova
Instructions to install tv Tunner
Old Jan 26, 2003 | 12:14 PM
Javiertres's Avatar
S 320 cdi
Question Instructions to install tv Tunner
Somebody has the instructions to install the Comand TV-tunner
in the Comand 2,5 S Class
Many Thanks
Javier
Old Jan 27, 2003 | 11:48 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Buy the OEM MB wire harness and connect the comand with the TV tuner...all ready to go and as easy as can be (but expensive).
You can buy aftermarket wiring harnesses as well for less then half the MB price...unless you want to make your own wire harness...I don't know if that is what you planed to do?
greetingz,
Old Jan 27, 2003 | 03:49 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
There are 2 wiring harnesses available - one with the rear TV screen wiring, one without.
If you want the rear screen wiring, then U have to buy the MB one.
Id always buy the OEM one for the car, it fits nicely :-)
You also need a different antenna base (at top of rear windscreen) which has the amplifiers for the extra aerials - so the TV tuner has 4 aerials and picks the stongest signal.
You also need the bracket that the TV tuner mounts in - but I dont know where that fits on a S class and/or if you need other parts ...
It may be cheaper [but may not be, with the Euro] to buy the harness from a German dealer - certainly cheaper than UK dealers.
R
Old Jan 27, 2003 | 04:25 PM
Javiertres's Avatar
S 320 cdi
Many Thanks
Many thanks MBenzNl and Richard for yours in detail instructions, and sorry not to extend, but my english is very bad.
Thank you
Javier
Old Jan 31, 2003 | 10:01 AM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
Installation
On a US car (S500), do you have to remove the headliner to perform this installation?
Old Jan 31, 2003 | 10:06 AM
Richard's Avatar
Re: Installation
I think you only need to drop it down at the rear to get to the
aerial amps - Im pretty sure its no more than that ..
R
Old Feb 7, 2003 | 01:49 AM
dragonrt's Avatar
2000 S500 Designo Edition
Hi MBenzNl and Richard,
Do you have the list of OEM parts and where to get them from in order to retrofit the tv tuner to the S500 '00 COMAND ?
Thanks,
