Sponsored by: Innova
chrome key vs. original key adapting ?
Old Mar 10, 2009 | 04:40 PM
lepez's Avatar
CLS320cdi, GL350BT, ML270cdi
hi,
I'd like to know if there is a possibility to build the microchip from a older smartkey into the housing of a new (chrome) smartkey.
ex: I want to build the internal software chip from the lower key into the housing of the upper key
it's because I have a chrome smartkey laying around here , a broken one from my job, car was in garantee so customer got a new one...
also, I drive a W203 wagon, and it's not yet possible to order a chrome key for a wagon... however, for a sedan it is possible :s
has anyone a DIY or has anyone done this before?
grtz
Old Mar 10, 2009 | 05:59 PM
UK-C200's Avatar
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Who told you that you couldn't order a chrome smartkey for a W203 wagon?!
Old Mar 10, 2009 | 07:29 PM
lepez's Avatar
since I work in a MB garage ... i have looked it up a few times, and, at the moment, they are still normal one's...
it could be they send a chrome, but we haven't yet ordered one for someone else so ... and i'm not gonna spend 200 € yet, because i have a chrome key here. it is a "broken" one, but i thouht i might be able to put in the control-unit (or whatever it's called) from the normal black one in the chrome one ...
Old Mar 10, 2009 | 07:37 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
All depends on your skills and how comfortable you are opening up both keys to see if you can do a swap.
Old Mar 10, 2009 | 10:08 PM
05clk500Art's Avatar
95civicsi, 2001 e320, 2001 integra type-r, 2005 clk500
i was planning on do this my self but i cant fine a chrome key yet. so if you get it to work please share how you did it
thanks
Old Mar 11, 2009 | 04:54 PM
michaelscoots's Avatar
'95 e320 Wagon, '92 300TE
Hey guys,
Check out post #730 on this thread:
https://mbworld.org/forums/c-class-w...-class-15.html
Although I haven't done this myself (was thinking of doing it), it appears as though it's possible. But you'll need to take the two boards to a welder / someone with a hot air station.
Let me know if any of you do this to your keys.
Michael
Old Mar 12, 2009 | 12:40 AM
HUMM looks good, any one wit a chrome key for sale?
Old Mar 14, 2009 | 02:17 AM
E500 Benzo's Avatar
2003 E500 Sport, 1995 SL320
all new benz keys are the chrome type. it has nothing to do with the model range... as long as the car has a IR/smartkey any new key ordered will be a chrome one. they dont even build the old plastic ones any longer
Old Mar 14, 2009 | 12:08 PM
JonMBZ's Avatar
06 C55, 09 E350
I can probably get you one, but I don't know if they will fit properly.
Old Mar 15, 2009 | 02:22 AM
what do you mean??
Old Mar 15, 2009 | 02:44 AM
whoover's Avatar
'19 E63S sedan
Another problem with swapping the innards: the mechanical key is different. Your old blade key won't fit into the chrome key.
I agree that all new keys are the chrome kind, so just order one.
Old Nov 14, 2009 | 06:55 PM
MERE200's Avatar
W210 E220 CDI
I have the same keys (without Panic button) I removed the chip of the chrome key and transplanted the chip from the old key. My chrome key works ! (Chip = NEC56788...)
Old Nov 14, 2009 | 08:43 PM
SoCal208's Avatar
12E350, 12ML350, 08C350
hi,
grtz
DO a search : I read in this forum : someone in Spain had swap the chip from the old key to the new key (chrome), with pictures & instructions, you need to have a skill in electronic to remove the chip out the OLD key, then weld it in the slot of the new (chrome key). Good luck.
Old Jul 8, 2010 | 10:07 PM
mtrevelino's Avatar
2006 E320 CDI
Can someone post or email me (mtrevelino@hotmail.com) the pdf file that is located under post #5 here:
http://www.benzworld.org/forums/w210...available.html
I tried registering at this site but cannot figure out their weird verification question.
Thank you,
Mike T.
Old Jul 9, 2010 | 05:33 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Thank you,
Mike T.
Here's a LINK to that PDF Mike, and I'm emailing it to you as well. Maybe you'll send me the next "broken" chrome key you come across and I'll try it too!
Old Jul 9, 2010 | 10:32 PM
mtrevelino's Avatar
2006 E320 CDI
I am having the same problem that Whoover mentioned, the mechanical keys are different. I sent a email to my service advisor and am waiting to see how much Mercedes will charge to either program the remote and cut a new mechanical key, or what will the costs be for a new key.
Mike T.
Old Jul 13, 2010 | 09:11 PM
JonMBZ's Avatar
06 C55, 09 E350
You can order the mechanical key for any style key it should be less than 10 dollars.
203-766-50-06 Chrome style key Version 1
212-760-19-06 updated Chrome style key with triangle panic button Version 2
The transplant is not easy unless you have experience doing things with small circuit boards/soldering.
If you woud like to order the chrome style wagon 2 button remote with version 2 which is better because it doesnt crack as much try this part# combo, give it to the dealer if they are having trouble.
169-766-34-06-9999 KEY
212-760-19-06 MASTER KE
