Sponsored by: Innova
DVD navigation help
Old Mar 15, 2009 | 04:06 PM
MBE550's Avatar
2014 E350, 2015 ML350, 2017 X5
DVD navigation help
I just bought 2007 E550 with DVD Command Navigation.
DVD seems to work but there is no disk in the dvd drive (in the trunk)
Is this right? I thought maps are data are read from DVD directly, and there is no hard disk.
How would I find out what version of map data I have.
Can I use the latest version Mercedes-Benz Harman Becker COMAND - North America Map DVD v.8.0 without any update to the firmware?
Thanks.
Old Mar 15, 2009 | 08:33 PM
JonMBZ's Avatar
06 C55, 09 E350
There is no hard drive in that vehicle, you need a disk. some require an update depending on the disk that was in the vehicle before the new disk.
Old Mar 15, 2009 | 10:16 PM
MBE550's Avatar
Hmm, that's why I was asking.
There is no disk in the Navigation DVD drive, but GPS works.
Shouldn't it say there is no disk, and not work?
Can someone with 2007 E class cofirm this?
Thanks.
Old Mar 18, 2009 | 01:07 AM
JonMBZ's Avatar
06 C55, 09 E350
Hit the eject button, it cannot work without a disk.
Old Mar 18, 2009 | 05:23 PM
Arctic 350's Avatar
2007 E350 Sport Pkg.
Need a disk.. just bought my E350 2007 and the nav is not working cause it is missing the dvd.. which by the way, can anyone tell me what the best way to find a replacement disc? The dealer wants 250 for the set and I only need SouthEast??
Thanks and good luck
Old Mar 18, 2009 | 09:01 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Your car's DVD-based system has all of North America on a single disc. Choices for getting one are the dealer, NavTeq (http://www.navigation.com/is-bin/INT...llProducts=YES - about $50 less than the dealer, but exactly the same disc - they make them for MB), ebay, or from a private individual.
With all the road construction around Tampa, I recommend the latest disc. Be aware, though, that the database for the discs lags actual road construction. For example, the downtown roads are OK, but the changes opened in September '08 at the Bruce B. Downs and I-75 intersection aren't in the system yet.
Old Mar 18, 2009 | 11:30 PM
MBE550's Avatar
My salesman today showed me how to eject the DVD disk.
The eject button needs to be hold down until the disk comes out.
I do need the updated disk.
It looks like there are different versions based on the model of the car.
Does anyone have the latest disk for 2007 E550? and provide an input on how good the data is?
Also, is there any update to the GPS software itself, not the map data?
Old Mar 19, 2009 | 12:16 AM
acr2001's Avatar
2012 C300 4Matic
The GPS software updates are included on the new map DVD. It will install any updates when you first insert the new disk.
Old Mar 19, 2009 | 12:27 AM
Skylaw's Avatar
And the latest disc can be found at the NavTeq link I gave in post #6. You are also able to see a list of locations with significant changes once you get to the version for your car.
Old Mar 19, 2009 | 01:05 AM
MBE550's Avatar
Thanks.
It looks like this is the latest for 2007 E class:
  • Release Date November 2008
  • Catalog # U0028-0070-809
Do you know if this one gives bird's eye view?
My friend just upgrade map on his 2003 m5 which added bird's eye view.
BTW, the GPS in his car looks almost same as mine including the software menu and interface.
Old Mar 19, 2009 | 08:21 AM
Skylaw's Avatar
That is the DVD I have, and it provides a "Bird's Eye View" option - but every disc I have had for my '05 provided that option. It is not specific to a particular DVD. Did you use the "Display" and then "View" option menu that you get when you have either "Nav" or "Map" functions activated? Your COMAND manual discusses how to do this.
Do not let appearances fool you regarding COMANDS, especially assuming that a BMW's works like a Mercedes. Even different models of COMAND in Mercedes do not work just alike.
BTW - it's a matter of preference - but I find the 2D display oriented to the car's heading to be the clearest and most easily understood. To me, the Bird's Eye View is an interesting gimmick, but nothing more.
Selling you a copy of a copyrighted DVD is blatant piracy, and could subject you and the seller to criminal penalties, whether the Board allows it or not.
Old Mar 19, 2009 | 08:48 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
MBWorld does not condone such activities. Its a violation of the TOS/TOU and therefore subject to disciplinary action.
Old Mar 19, 2009 | 09:43 AM
MBE550's Avatar
If it's something I want to actually use it, I'm buying the original.
I have 3 garmin nuvis and have updated map on each one. Basically, I have paid Navteq 6 times for map software, but that's ok.
Old Mar 19, 2009 | 06:46 PM
MBE550's Avatar
I just checked my GPS some more.
It looks like it does not have 3D view mode.
I think I have seen somewhere 2007 E class should have 3D view.
Does anyone know if new DVD disk will actaully add this capability as well?
I have seen ref. to new E class having NTG 2.5. Which version does 2007 have? I searched everywhere and couldn't find this info.
Thanks.
Old Mar 20, 2009 | 03:33 PM
Skylaw's Avatar
Again, 3D (Bird's eye view) mode is not disc-specific. The nav DVDs will update nav firmware, but not your COMAND. Ask your dealer if a firmware update for your COMAND unit will provide it.
Old Apr 13, 2009 | 07:13 PM
atheymd's Avatar
2006 Benz E320cdi
Mercedes-Benz Harman Becker COMAND - North America Map DVD v.8.0 * Release Date November 2008 * Catalog # U0028-0070-809
Availability: In Stock
NAVTEQ Direct Price: $ 249.00
Old Nov 3, 2009 | 03:19 AM
dhho1's Avatar
2007 E550
is the latest DVD map worth the money? my 2007 DVD nav directs you to the block of number instead to the exact house number for a DVD navigation. That is pretty ****ty in any standard. my $99 portable unit directs me to the front of the address. Not the beginning of the block.
Old Nov 3, 2009 | 02:18 PM
Mackhack's Avatar
v9 is the latest version. Came out last month.
http://www.navigation.com/is-bin/INT...gationMenu=YES
