Sponsored by: Innova
Module for disable tv on moving
Old Jan 29, 2003 | 05:37 AM
cone's Avatar
2013 SL 350, ML 350 BT
I saw there are modules for disable tv while car is running. Do you know it? Do you know how they work?
I saw it in this page:
www.tectronics.com
Old Jan 29, 2003 | 07:08 AM
NightSea's Avatar
S600L/SL55
Hi
There is a similar one for MB w140 models at Japan.
Its picture is attached below.
Price is about $40.
I don't know if it is made in Japan or not.
How does it work?
As I understand, there is a sensor which checks the car speed and sends a signal to COMAND system continuously.
This module makes and sends a fixed false signal(instead of
the true module signal) to COMAND system ,
so that COMAND will think the speed is very low no matter
what the real speed is. As a result there will be no screen
cut-off signal and you can watch TV without blocking.
Old Jan 29, 2003 | 07:15 AM
cone's Avatar
Re: ....
Originally posted by NightSea
Hi
Price is about $40.
How does it work?
I wonder if this dvice send a false signal to the comand, what happen when you are using navigation system?
How is your work in your car?
Where did you find that module?
Old Jan 29, 2003 | 09:47 PM
NightSea's Avatar
S600L/SL55
Re: Re: ....
That module has a selecter switch.
It is a kind of on-off switch.
Regarding my work for my car,
though I have necessary software and hardware,
no time to concentrate on trying.
I hope I can try it by early Feb.
This module you can see at www.threepoint.co.jp/18.html
(This is not English site.)
Old Feb 9, 2003 | 02:33 PM
cone's Avatar
Re: Module for disable tv on moving
www.tectronics.com
Anyone in NL knows this company?
http://www.tachorob.nl
