Sponsored by: Innova
MP3'S IN CD PLAYER?
Old May 2, 2009 | 12:42 AM
steveberde's Avatar
E 500 4matic, MINI John Cooper Works
MP3'S IN CD PLAYER?
I have no 06 with the 6 changer CDC plus the single CD player - the Comand states that it will play MP3 recorded music however when I insert it in to the CD player I recieve n "error" prompt - Any suggestions?
Steve
Old May 28, 2009 | 03:26 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
Typically the CD changer plays the MP3's (and WMA) files,the single CD player
plays nothing but CD's. I've had mine for about two years and that's what i get....
Old May 29, 2009 | 12:48 AM
JonMBZ's Avatar
06 C55, 09 E350
I can play mp3s fine in my car the changer only shows up to 99 tracks if I put it into the command it shows all of the songs.
Old May 29, 2009 | 02:08 AM
Gabe007's Avatar
2007 CLS 550 (Black)
Steve
Mine says it's MP3 capable... but when I insert the MP3 disk in the CD changer (I only tried slot 6), I get the "error" prompt.
When I insert the MP3 disk in the single disk CD player, it shows the "compact disc" logo, then it does nothing... When I press the Audio button, the CD "tab" is transparent/greyed out, and I can't select it.
Old May 29, 2009 | 03:09 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
Hey just wondering what kind of comand unit you have in your C55 is it a U.S or Euro Comand that plays MP3's and what year or version of DVD you are useing for maps?
Old May 30, 2009 | 07:20 PM
JonMBZ's Avatar
06 C55, 09 E350
I have 203-870-72-89 USA Alpine command im not sure about the NAV disk I rarely use it because it's a pain in the *** and I hate it. You also might want to try better media like verbatim CD-R and burn it as a data disk
Old May 31, 2009 | 09:24 PM
Preet's Avatar
Thanks i will try that, so you don't know the what year your map (Nav) dvd is?
Old Jun 1, 2009 | 02:08 PM
JonMBZ's Avatar
06 C55, 09 E350
I can check if I remember next time im in the car, but I got the car used and I never looked at it.
Old Jun 6, 2009 | 10:41 AM
ruffrob's Avatar
That's all I use,and the results are excellent....
Old Jun 6, 2009 | 05:46 PM
Preet's Avatar
So now that you have burned MP3's on a verbatim CD-R as a data cd you are able to play MP3 on the single CD player
Old Jun 7, 2009 | 01:54 AM
ruffrob's Avatar
See here's the thing ,Preet. I had a changer like yours,and once i realized that it couldn't/wouldn't/doesn't play MP3,I went to EBAY and got this
http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW
It's been great ever since,because ,primarily,it's what you have to play them with first,before what you have to play. Good Luck
Old Jun 7, 2009 | 12:43 PM
Preet's Avatar
Thanks for the info, i already have the 6 disk MP3 CD changer, but i was trying to play MP3 on my comand unit
Old Jun 7, 2009 | 12:48 PM
ruffrob's Avatar
Sorry for my misinterpretation,I truly wonder if anyone has MP3 playback in that player. It probably exists,although i don't remember seeing one. Good Luck with finding one..
Old Jun 7, 2009 | 12:59 PM
percykwong's Avatar
13 S550, 10 S550, 08 GL550, 05 SL65, 97 SL600, 09 E63
Ironically, I finally decided to put some music in the car and have been grappling with some mp3 issues, but simply put, the dash does play mp3s. (I have DVD navigation + CDC). It'll work with mp3 DVDs, although I'm trying to figure out why some folders show songs available and others are empty (even though they do have the mp3s in them).
I'm currently experimenting with mp3 CDs in the CDC. (working on them now). I'll post results if you guys are interested.
Cheers.
Old Jun 7, 2009 | 01:13 PM
ruffrob's Avatar
Yes ,interested,although,it would have to be a totally different head unit for me to play MP3 from a DVD..
Old Jun 7, 2009 | 03:01 PM
sun72's Avatar
SL55 AMG
I learned the hard way by trial and error...I can play mp3's in the single dash ONLY after I save them in sub-folders...and even then, I can only play up to 99 songs per sub-folder....I have each folder labelled alphabetically and all works fine now
Old Jun 11, 2009 | 07:41 PM
Gabe007's Avatar
What is the folder structure of your cd? Is it like this?
D:\
-Folder1
---song1.mp3
---song2.mp3
---song3.mp3
---song4.mp3
-Folder2
---song1a.mp3
---song2a.mp3
---song3a.mp3
---song4a.mp3
-Folder3
---song1b.mp3
---song2b.mp3
---song3b.mp3
---song4b.mp3
Old Jun 11, 2009 | 07:43 PM
Gabe007's Avatar
Also, was it a CD or DVD?
Old Jun 11, 2009 | 07:54 PM
sun72's Avatar
SL55 AMG
yes, that is the folder structure and I used a CD
Old Jun 12, 2009 | 11:10 AM
percykwong's Avatar
OK, here are my results / findings:
MP3 CDs work wonderfully, but what I found is that my system had problems with mp3 bitrates above 160kbps. I just re-encoded to 128kbps and set up the folder structure accordingly.
Artist / Album / Song
or
Genre / Artist / Album / Song
It worked fine that way for me.
Old Jun 12, 2009 | 11:13 AM
percykwong's Avatar
I'm actually thinking about just doing some reverse engineering with an EE friend of mine and building an MP3 jukebox system that will replace the CDC. It'll have full compatibility with the dash / comand unit. (One of my hobbies is reverse engineering tech).
As long as the communications aren't encrypted, it'll be a cakewalk figuring out the protocol.
Old Jun 12, 2009 | 11:22 AM
ruffrob's Avatar
How do they sound??
MP3 files below 192kbps sometimes sound crappy...
Old Jun 12, 2009 | 11:26 AM
percykwong's Avatar
It's not too bad. You just need a good encoder. I use winlame. Also, remember to equalize the sound prior to transcoding into 128kbps. It's definitely acceptable in a convertable. My mp3s sound great when I transcode down to 128kbps, but I actually spend the time to pre-equalize / tailor the sound prior to the final transcode.
Old Jun 12, 2009 | 01:28 PM
Gabe007's Avatar
or
It looks like your folder structures go down 3 or 4 levels...(I was thinking of using multiple 1 level folder and just dump mp3s in it.) What's the limit on how many mp3s can you store in your "Song" folder? (Sun72 says 99 is the max, can you confirm?).
What do you mean problems? Does it work but the sound is crappy? (Like mentioned below?) Or does it not work at all if it's above 128kbps?
How do they sound??
Old Jun 14, 2009 | 05:11 PM
ALNiKO-W211's Avatar
Ford Mustang '05, S320 '99
Hi! I have 04 CL500. Comand can read MP3 discs but even if I burn them using lowest speed my burner can set (4x) I'm getting skips at different parts(mostly the last minutes) of some tracks (let's say 40%). Tried to use Maxwell CD Lens Cleaner and didn't get any effect. Audio CDs do the same thing - 7 out of 12 tracks play perfect while the rest have skips or don't play at all. What to do?
