Navagation Glitch ?
I have a 2000 S430. Latly I have been using the navagaiton and the directions are always wrong. It was working fine just until a couple of days ago. Is there a way to reset the system. I even did a find my location and it was worng. I even cleand the CD and same problem.
Any help would be greatly appreciated.
Powerplyer
I think theres no harm in doing it, as it worked for me and dealer recommended it (in UK)
But try at your own risk. .
Kind Regards
N
thanks for the resonse. Do you know where it is I have not a clue. I know how to take a fuse out, but where is it. Also, did you try this on an s class?
Thanks.
I have a CLK, you will have look at your manual for the fuse box, and with your toolkit (spanner, tire stuff, etc...) there will be a small white plastic tool to remove and install fuses. The fuse box is under the hood (in my case it was, but there are 3 seperate fuse boxes) But in the one under the hood there is a card which will tell you which one is for the COMAND. Pull it out for 10-12 mins and put it back in. Try that.
N
