HK Subwoofer pinouts
I have a 09 ML350 with HK sound upgrade.
I am trying to install a subwoofer box in the trunk and need the easiest signal input to my amp. I removed the plug from the HK sub and there is 4 wires going into a single speaker.
Can anyone help me to figure out which wire is what?
Thanks in advance!
Again, SORRY and THANKS.
I understand that you would NEVER EVER, keep the stock base speaker functioning. I got that, I would not want it either.
Maybe my question should have read as follows:
Should I run both pairs of speaker leads into the high-sensitivity amp inputs or will this create a problem?
Is this the 'Y" to the amp that you mentioned before?
It seems that if both sets of leads are seeing the same signal, that it would be OK. Or, is there an impedence issue with the two sets of inputs?
If not both pairs, then one pair to the amp and the other pair taped up and connected to nothing?
Once again, thank you.
