Sponsored by: Innova
subwoofers play at 0
Old Jun 29, 2009 | 01:38 AM
skokkosis's Avatar
2014 E63-S, 1987 190E 2.3-16, 1985 325E
so... just searching for some help on MB in case someone has knowledge beyond mercedes i just fully installed 2 elemental designs into my friends acura tl-s... properly done (positive to battery, negative to body, remote taken care of) for at least my knowledge i am sure that everything has been put together properly... the signal is being picked up from the stock subwoofers wiring and then connected to a converter then rca cables to the amp... the issue we are hving is the subs work perfectly fine when the car is in ignition and on (while driving) if the car is in stall (ex. at a light or in park) the subwoofers sound like a lambo engine they just sound like a constant repetitive vibrating noise) i can not figure from where and how this could happen any help?
Old Jun 30, 2009 | 08:51 AM
jbondox's Avatar
beater with a heater
check your ground.
check your wire run also, especially if it nears the brake pedal. further it could be the remote turn on, where did you get that? possibly a wire that tests ignition but isn't, i hope you didn't get it off the brake lights or similar.
