Sub install question
2004 SLK Special Edition
I've got an Infinity Basslink and I was just wondering if any of you guys have installed one before. I have a 2002 coupe with Bose and the nav system so Im not sure if that makes things more complicated or not. I was planning on leaving the Bose sub intact and still working unless that is a bad idea. I just want to make sure that when I sell the car I can pull the Infinity out and have eveything stock all over again. Any help/instructions/pictures would be great. Thanks alot.
BMW 740iL
if i was you i would return the infinity basslink and get yourself some alpin type r subs or focals. just have someone install it fo you because its alot cheaper and they no what there doing. if you live in southern california i can probably help you.
I got alot of help from people on the forum and finished installing the sub myself a few days ago. It works great and I have the exact same setup as you...Bose Command, 2002 coupe. It was pretty easy to do but took some time. It could actually be done in like 1 hour if you didn't take the time to run the wires under the carpet. If you search for the thread "need help installing amp/sub" It's the one that I used to get help. I can answer any questions and tell you what to do if you need it. Good luck
