Sponsored by: Innova
6210 UPDATED TO 6310i is possible
Old Mar 10, 2003 | 12:07 PM
d8ean's Avatar
costs about 5-600 quid over here in the uk - this doesn't include the phone! - having it done in the next few days!!
they update the cars software, and place a new cradle in and also a brain control thingy!
see how it is!
Old Mar 10, 2003 | 01:19 PM
barflux's Avatar
CLK 320 Avantgarde
Hey if you do it yourself it will cost about £300 if not less
If you have 6210 kit, all you need is to the swap the controller £230) (can be tricky, but it is ok on the CLK), not sure what you have though.
N
ps you don't need the adapter as Richard said, just the controller and possibly software upgrade. If you can send sms then you don't need it as I think that is the latest.
Old Mar 10, 2003 | 04:54 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
As barflux says, its trivial to do
You wont need the cradle adapter because its already there for the 6210. You might need a new cradle, but probably not - some of the older cradles the phone drops out), and you need a new control unit.
The phone is available free on a contract ..
The controller is, either under the rear seat (CL/S), in the boot (middle under carpet, under cover)(new C), or behind one of the side panel trims in the boot (old C/E/CLK/old SL), or under the right-hand seat (ML). Its harder to get to on the new SL.
(UK boot == US trunk)
Cheers
R
Old Mar 10, 2003 | 05:01 PM
Richard's Avatar
Sounds like they are updating the s/w on the COMAND unit, which gives you a few newer features on older cars.
But, you can get them to do that for free if you say "sometimes the CD player starts from track 1, sometime from where you left off - and apparently there is a software update for COMAND"
Dont let them charge you the 30minutes labour for sticking the update CD in ...
R
(ps, which dealer?)
Old Mar 14, 2003 | 03:31 AM
d8ean's Avatar
rivervale in brighton
im having a software update and a new brain thingy - cant remeber the name - this is all on a cl 500
Old Mar 14, 2003 | 04:04 AM
Richard's Avatar
The brain is under the rear seat - maff changed his in about 10 minutes. The software update is a CD you stick in the COMAND and leave it well alone for 20 minutes ..
R
Old Mar 14, 2003 | 04:06 AM
d8ean's Avatar
all very well but when you dont have the means to do this - then it may aswell be built in the engine....
Old Mar 14, 2003 | 04:13 AM
Richard's Avatar
Well, I can give you the part number for the update CD (which costs about £10), and the new brain (which is about £200 I think) - and if you have a posidrive screwdriver then you can do this easily.
The rear seat bench lifts up, there are catches in the front corners of the bench (you cant see them, they are behind the leather) that you press whilst pulling up the seat - once youve done one, its easy to see how the work, but first time is more difficult ..
If they are changing the cradle aswell, that is more difficult to do - but I suspect they arent ..
Cheers,
R
Old Mar 14, 2003 | 04:27 AM
d8ean's Avatar
the cradle is being replaced too! as the new 6310i isn't as good fit as the 6210....
i'd rather have it done correctly so that if anything does go wrong then it is all covered!
Old Mar 14, 2003 | 04:33 AM
Richard's Avatar
Hokay - I guess Im just an inane "fiddler" and like to do stuff like this myself (even on a ML500/SL55 !)
R
Old Mar 14, 2003 | 04:43 AM
d8ean's Avatar
im the same - only my car (Box S) but to be fair i haven't the time and also the patients at the moment!
Its my old mans motor that needs the upgrade and he wants it sorted ASAP......
ML & SL - both nice rides!!
Deano
