Sponsored by: Innova
03 CL 55 Command System
Old Mar 11, 2003 | 12:54 AM
nduarte's Avatar
2003 CL 55 AMG
Can someone please help me with what i need to buy to enable the new Command to play Playstation 2 or DVD. Will the megacomm adapter work if so which one ... Thanksss
Old Mar 11, 2003 | 05:37 AM
cone's Avatar
2013 SL 350, ML 350 BT
Re: 03 CL 55 Command System
Yes, it works, but your MB dealer must activate TV knob on your Comand, the problem is that while your car is running, you can´t wach DVD because your display is turning black. The best solution, is to send your Comand to Megacomm, they will activate TV knob and disable TV on moving. They did it in my 2003 S class, it works fine. You can email them to shop@megacomm.de
Old Mar 11, 2003 | 01:01 PM
nduarte's Avatar
2003 CL 55 AMG
03 Command in the USA dosent have the YV button thogh so is it still possible, please explain....... ANd HOW MUCH will it cost?
thanks again
Old Mar 11, 2003 | 01:04 PM
nduarte's Avatar
2003 CL 55 AMG
oops im sorry the USA command dosent have the TV button
cone's Avatar
thanks again
Can you post a pic of your comand? It cost 149€.
Old Mar 11, 2003 | 01:16 PM
nduarte's Avatar
2003 CL 55 AMG
WOW!!! Hey thanks for the RAPID response, i dont have a pic of my actual command however i know it is exactly the same as yours with the 6.5 inch wide screen except where your command has the button labeled TV here in the states the button is there but is not labeled anything its just blank with nothing. You can press it down as all the other buttons however nothin happens... so will the megacomm still work.....
Old Mar 11, 2003 | 01:22 PM
cone's Avatar
I didn´t know that US comand hasn´t TV button, I´m afraid you can´t use Megacomm av adapter, I think you must email them for get to know
Old Mar 11, 2003 | 01:38 PM
nduarte's Avatar
2003 CL 55 AMG
Thanks anyhow for your quick reponses!!!!
Old Mar 11, 2003 | 01:42 PM
cone's Avatar
In this moment, I´m on line, that is why so quick...
Please, when you have a response from Megacomm, let us know
Old Mar 11, 2003 | 02:37 PM
awiner's Avatar
2003 CL55 AMG
The US COMAND does not have TV silkscreend on the button. Just a blank button, however, the dealer cna still program via DAS the use of that blank button as a TV button.
Old Mar 11, 2003 | 03:00 PM
nduarte's Avatar
2003 CL 55 AMG
awiner,
have you had this done? Also would there be and functionability lost to the command? Would i need any other equipment in order to have the Playstation 2 and DVD play on the command? Also sorry for all the questions but i to am in California/ bay area perhaps you can refer me to a dealer that would be willing to program via DAS
thanks again awiner please advise me
Old Mar 11, 2003 | 04:21 PM
awiner's Avatar
2003 CL55 AMG
I have not had this done. However, there has been an enormous amount of conversation on this forum about it. Doing a search will probably yield a large amount of information. I am sure someone will be able to answer most of these questions in a timely manner.
Old Mar 11, 2003 | 06:29 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Hi nduarte,
In case you still need that/a new euro comand for your car...I have it now...
greetingz,
Old Mar 11, 2003 | 06:36 PM
Davidta's Avatar
C230 Kompressor SPORTS COUPE
I had my dealer activate the TV botton and it works fine, though I don't have anything to use it with at the moment...
Old Mar 11, 2003 | 10:57 PM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
If your dealer activates this button, how do you hook up a dvd or X box? Does it require much wiring work?
Old Mar 11, 2003 | 11:37 PM
nduarte's Avatar
2003 CL 55 AMG
Yes i do need the Euro command please inform on what i need to do in order to obtain the command from you. Also will this command allow me to play the playstation 2 and or DVD? If yes will i need anything else to accompany the command? And will my USA command work or do i definitely need a EURO command?
Will you be doing any installs in the California bay area.....?
Old Mar 12, 2003 | 02:46 AM
MBenzNL's Avatar
some slow@$$diesels
To Be able to connect a DVD player or playstation to comand you need an RGB connector...I can bring those as well...
I will most probably be in california to do some comand installs again in the second half of april/beginning of may...LA area and the bay area.
greetingz,
Old Mar 12, 2003 | 10:29 AM
Crankin's Avatar
MbenzNL question
Can this RGB connector be used effectively with a 2000 US COMAND, assuming the MB dealer activates the tv button?
Is a DIY or is it difficult to hook up?
Old Mar 12, 2003 | 11:25 AM
cone's Avatar
Re: MbenzNL question
More questions:
A- Do they need to change US comand instead Euro comand?
B- If not, can their dealer activate their blank button as TV button?
C-Do they need to disable TV interlocks for watch AV source while running?
D-Does the Megacomm AV adapter works with US comand?
Old Mar 12, 2003 | 12:49 PM
nduarte's Avatar
2003 CL 55 AMG
steve,.
are you able to send me the command and rgb connector ASAP and direct me to where i would need to send you the certified payment. Also how much will you charge for the both of them.
thankss again
Old Mar 19, 2003 | 04:43 AM
cone's Avatar
steve,.
thankss again
Hi, I think you have an easy way to do it. I tell you what I did. My dealer disasembled my Comand Unit from my car (2003 S class) it is very easy, about 10 minutes. I send my unit to Megacomm, they activate TV button (In yours, blank button), disabled TV interlocks for watch AV signal in motion and plug Megacom AV interface, you can fit you DVD unit in your glove compartment. It works perfect
