Sponsored by: Innova
w210 1999 Head Replacement
Old Dec 16, 2009 | 03:53 PM
qasabah's Avatar
e320 1999
I've posted ths at benzworld.org but had no replies.
I have a 1999 320 E factory Head with 6 disc changer in the trunk.
I want to replace the head unit with one that will allow me to plug in an iPod directly. I have looked at the Becker aux-in modification but am turned off by the idea of the tape drive churning away
I don't care about the 6 disc changer as it is broken and I will remove it.Perhaps i can use the disc changer's output somehow?
I currently use an iPod with a radio transmitter but the sound quality is not very good. I also think it looks untidy.
Other than size are there any restrictions or tricks to what unit I can replace the factory head unit with?
I have read conflicting information that there is a Bose amplifier hiding in the car somewhere that may cause volume issues but cannot find consistent information on this. Apparently there is a bose amplifier in the trunk. Unless this was an option...
I then followed up with...
I've looked through a lot more posts and still have a few questions and observations.
Apparently there is a Bose amplifier in the trunk of the car but I have a few questions about it.
* was it standard equipment?
* in the 1999 w210 is it attached by fibre optic cable?
* which speakers does it amplify the signal for?
It seems that a volkswagen adapter is the way to go but I have a few questions about this too.
* I understand that it depends on the head you want to attach but are there any aftermarket manufacturers that are not supported?
* The gain has to be set down(?) to put the volume in a useable range but other than this will the current speaker set-up work with an aftermarket head?
Has anyone installed a single din head unit?
Does anyone know any MB friendly head units (even if they are more expensive?
Old Dec 17, 2009 | 12:20 PM
jbondox's Avatar
beater with a heater
replace with an alpine after market unit
Old Dec 17, 2009 | 05:31 PM
qasabah's Avatar
e320 1999
Is there any particular model? Do they have particular harnesses?
Old Dec 18, 2009 | 03:31 AM
jbondox's Avatar
cda 9886, will need to be hard wired but you can try the VW harness just verify the pins are correct
Old Dec 18, 2009 | 08:21 AM
qasabah's Avatar
e320 1999
Thank you for your replies.
What does "hard wired" mean?
What are the advantages of using the alpine? Is it aesthetics or is there no gain issue or something?
Old Dec 18, 2009 | 08:47 AM
jbondox's Avatar
hard wire means no harness and splice into it
alpine is my brand of preference. I have tried everything out there and always come back to alpine
Old Dec 18, 2009 | 01:26 PM
qasabah's Avatar
e320 1999
Do you know of a wiring guide? Will the amp be remotely powered too or do I need to run a separate switch?
