Sponsored by: Innova
NTG 2.5 Engineering Menu - RGB connection?
Old Jan 28, 2010 | 01:37 PM
shimmers's Avatar
W204 C63 / W212 E63
Hi, in my W204 and W219 NTG 2.5 within the Engineering Menu (and also via Star), there is an option of "Retrofit Navi" which you can set to FBAS, Y/C or RGB. When I set it to FBAS it allows for video feed via the Green Fakra in the back which is displayed on the Comand screen when I press the Navi button. Obviously this is a way of installing a 3rd party navigation system that has composite video out.
Since the option also has RGB, I need to know where to connect the RGB wires to the Comand. It would not be the Green Fakra and the only other available plug would be the blue one which I believe is for the TV Tuner (in Japan).
Does anyone know where the Comand can take in RGB signal so that when I set the "Retrofit Navi" option to RGB via Star, I can get the RGB singal to display on the Comand screen?
Thanks in advance.
