Amp & Subwoofer in 2008 C350
It's over a year later. Is there any plug and play or almost plug and play options to get a sub amped in my trunk?
Also, if I was to go with something like a Alpine INA-W900, and replace the head unit and put the screen in the dash, could I then use the screen that is on top of the dash as a video output?
More importantly, THE SUB!
If you get rid of the factory amp then you'll need to connect directly to the MOST optical system with a MOST PreAmp interface. http://www.mobridgeinc.com/products/preamp_DA2000 (not yet released)
If you keep the existing Amp and use speaker outputs with the Audison Bit One http://www.audison.eu/index_main.php?Section=BITONE
then you can add another Amp and reconnect the speakers.
Not sure how this would sound with factory speakers and factory amp still playing a major role in the sound production.
Last edited by peak_oil_101; Feb 25, 2010 at 04:24 PM. Reason: double check all because above info is for 2006 E320
how much is the audison bit one?
Actually, I looked up the preamp interface by mobride and it says that C-class is supported up to 2007.
Will my Sattelite still work? Aux input and iPod interface?
if u r doing a full system, the radio needs to be coded for internal amp to turn on and it is 20-20k hz +/- 2 db throughout
also use the bit1 from audison for control and EQ, the cleansweep has no business in that vehicle or any MB... outdated band aid
