subs keep locking up
what we are having a difficulty with is figuring out why the subs keep becoming toast in my car. I tapped off of the factory sub line..(non bose) and for some reason... after playing a while, the subs lock up and the amp goes into protect mode. About to get a volt meter and see if maybe the car is putting out something weird like 17volts due to a faulty volt regulator. Any other suggestions? It's not the audiolink and I have already relocated the ground cable.
Any ideas would be appreciated because I am stumped.
Try another temp cable just to test it.
I then swapped the amp and subs out for the set up in my work truck. It did the SAME thing again except it didn't toast the amp.... I had a 45 min drive where everything worked fine. The last thing I did was pull the last set of subs I have laying around...... and tried it connected to a home cd player, instead of the line from vehicle. After 15 mins.... the subs locked up once again. The whole point of me just putting in subs was to not spend too much money... lol..... now I am out an amp and my 2 sets of subs. Crutchfield will replace the first set of course so that means i have a set of subs to keep messing with til I figure out the problem
. It's just that no one can figure out what is up....... any more ideas guys?
nah..... 2 4ohm subs in parallel is a 2ohm load. the 500D handled that in my other car for 2 years. This is the simplest wiring possible..... which is why it's so frustrating now that it's doing this.
