MP3 CD Questions/Problems
I've burned an MP3 CD using iTunes, most of the songs quality of 320. Keeping size under 700MB. Once putting it into the COMAND (single disc) slot, it loads up, slowly. Then the song switching is also very slow, some songs it does not play at all. Sometimes it locks up. I've used this CD in the loaner I got (2010 w204 c300 w/ Audio50) and there absolutely NO problems. I currently have an 06 SLK55 with COMAND and I'm in the process of acquiring the upgrade disc.
My questions is as follows, are there particular requirements that I'm not meeting for burning this CD? (I don't want to try a DVD yet as I assume it'll take even longer to load). I'm hoping that the update will fix this but until then, I want to try everything possible to get this working flawlessly.
Good luck.
when you burn the CD, burn it at the slowest speed your software will allow.
have you tried a different burning program? I've used Nero, and burn the CD as a Data disc.
are all your songs in one folder? If you break them into different folders (albums), the software is only loading one folder at a time, in mine, it loads quicker.
I also burn mine at 192 instead of 320... with the roadnoise, I don't notice a discernable difference in the sound, I can get more on the disc, and it may affect the loading time, since there's less info being read.
I did burn DVD's with multiple folders.. think I got around 1100 on a DVD.
