2007 ML320 CDI: What do I need to install to use iphone ?
2007 ML320 CDI, 2008 GL320 CDI
Just bought a 2007 ML320 CDI. It does not have the Communication System nor an ipod adapter installed.
If I want to use my iphone using the Communication System, what parts do I need to install to make it work ?
Thanks for your help.
Look at the following illustration.
You need the phone electronics to support the connector (called MHI) in the top of the console.
Once you have that you can either install the bluetooth "puck" shown at right or get a cradle for your iPhone.
The cradle, incidentally, works just like the puck if you don't insert the phone, but if you do you get charging plus use of car's antenna.
![](https://mbworld.org/forums/attachments/audio-electronics/161649d1248059458-new-slk280-owner-command-phone-nav-image1.jpg)
Thanks Kent !
As far as the phone electronics goes, the dealer told me that it is not possible to install this at MB - they only install this at the factory for new cars. Could any audio car place do this job ? Any recommendations on where to get the phone electronics ?
I bet "not possible" is code for don't want to. Especially when they have to tell you the price! Couldn't do it where I live without going out of state, but you could check a second Mercedes dealer.
Contact MbenzNL, Steve, who works there has performed some miracles in the past that dealers said was not possibe to do.
quoted from earlier in another post
navtv tooki-mb.... done, regardless of the phone and regardless of what was wired... as long as you are on the MOST optical ring. otherwise the dealership would need to turn it on, and now a days, they don't have that ability thanks to sdnet
