2007 W211 Dension GW 500 install with IDC
I know a bunch of people have done this and it's worked out well, but I was hoping someone had a guide with steps and/or pictures. I've seen guides for 220s and 203s, but I'm mainly interested in knowing how to take apart my dash without breaking/snapping wood or plastic.
Additionally, if anyone has any tips learned through trial and error they'd like to share, that'd be great. I'm looking for ideas on where to place the GW 500, and if it's worth it to route the cables to the glovebox or where the cupholders are located in the center console.
Also, does the GW500 require a power tap somewhere, or is that taken care of by the plug and play connections. The documentation is so bad on their site, that I'm hoping someone can shed some light here.
Thanks!
Thanks!
1 Post
2006 e320 cdi
In my car, there is a hole between the center console and the area under the gear shifter cover (you'll see it once you remove the cup holder). I passed the ipod cable, and the usb cable through the hole from center console through the gear shifter area, through under the dash, into the passenger side where I installed GW 500.
Yes, you do need to tap the power. You can do it with the cigarette lighter, make sure you plug in the fuse such that the cigarette lighter has constant 12V. Or, you can do what I did, which is to run the wires all the way to the left side fuse box, and pick an empty fuse slot for the constant 12V.
Thanks for the tips. Were you able to pass the wires from the gearshift area to under the glovebox without removing anything else ? I think I'll probably keep the connections in the glovebox, simply because space is so limited with the cupholders in the center console. Since you can control all ipod functions through the COMAND or steering wheel buttons, no need to see the ipod or have close access to it.
Have you tried using an external hard drive connected via USB? I thought about buying a 2.5 portable one that's powered by the usb port and just using that instead of an ipod..
1 Post
2006 e320 cdi
I know that many people have used harddrive. I myself only tried with 8GB USB flash drive, worked flawlessly.
If you still are subscribed and can comment by chance, when you removed the fiber optic cable under the ash tray from its connector to the CDC player, you simply plugged that into the Dension port, and the lead that came from the Dension plugged back into this port under the ashtray, and that was it, making the GW500 in front on the CDC player in the fiber optic network? The second Fiber Optic lead that came in the kit is therefore not used, and there was no fiber optic wire reconfiguration within the terminals themselves like some installs in other models, or brands?
I have an 06 W211.
Many Thanks
I have an 06 W211.
Many Thanks
