1994 W140 s420 - Aux Input ?????
My guess is the "system" has to be on to energize the amp power supply.
My hope is by using the CD signal and the control button, I an keep the system hot and use the AUX as the signal source.
All wishful thinking until anyone with real tech knowledge tells me what/how to route etc..if at all possible.
Thanks in advance.
There are some creative people out there if they happen to stumble across the request.
Otherwise, I then have to decide if I trust a big box retailer to connect properly and a few readings of MB forums leave me doubtful.
I've seen the Becker DIY which shows how to hijack the tape player outputs with a soldered in AUX feed. Relatively cheap, limited features.
I've seen a link to ipodcarspro.com for a unit which plugs in place of trunk CD changer and claims to offer radio control of ipod. Under $150 for PA11-MB. Regular AUX input also available with no radio control features.
PA11-MB - CB-PM4 USA Spec iPod Adapter Interface for Mercedes (1994-1998)
I've seen Newegg items - two different FM transmitters direct wired to back of head unit antenna connection. Claims to offer better than wireless transmitter by disconnecting regular antenna when unit is active..both under $50
I've also heard Becker will overhaul an older head unit and add the AUX input for $100.
Anyone with experience on similar to above, your feedback would be appreciated.
Thanks.
