cl 55 xm antenna problem Help please
I'm not sure but I read/heard that the CLs have the GPS antenna on the trunk lid. Usually, like in the 208 CLKs and other cars that with GPS, the antennas are external and can be seen. I might be very wrong with this but I haven't observed an external antenna on the CL or S. Therefore, maybe placing the XM antenna where the GPS antenna is also located may work. If the GPS antenna was in the trunk lid, then maybe that portion of the trunk is 'thinned out' to allow the signal to penetrate. Again, this is only a theory and I am probably more wrong than right.
Good luck.
Ted
Bingo that was the spot on the inside it's a terk antenna shaped like a little rectangle. Unfortunatly you have to mount it upside down to get it to work correctly, but were are going to do is paint the back black so it has a finished look. At the very top off the glass
there is no interference and we almost never lost the signal.
Hope this helps
