Sponsored by: Innova
Stuck Stackers(Alpine 6 Disc)
Old Jan 4, 2011 | 03:02 AM
Shockvalue's Avatar
CLK320
My Alpine 6 CD stacker intermittently gets stuck and will not eject(CLK320). Not all that unusual it seems. A contributing factor is that it doesn't like some discs.
I accidently discovered this procedure which generally works:
First make sure the Command unit is on,
Then press the Eject button on the CD unit,
Then while the button is flashing turn off the Command unit.
The Cartridge usually will then eject - sometimes you have to repeat the procedure.
I'd be interested to hear if this works for others with this problem.
