Comand install Questions
Also, how can I modify the CANBUS command to no canbus?
Is there anything special I need to do for the bose system?
Before I buy the comand, does anyone have an ML MCS for sale as that is easier to install?
You can modify the CANBUS COMAND to non-CANBUS but it is a bit involved, also requires sourcing some surface mount transistors and soldering them on.
Steve (MBenzNL) probably has some non-CANBUS COMANDs for purchase.
For the Bose, your COMAND should have in its configuration settings "Analogous Bose" set to on.
-s-
