Audio 20 taken apart
History------ stock audio 20 on 04 plate CDi 220 showing CD error on the display-----will not accept a CD---------Unit removed from the car and dismantled old CD found to be stuck in the drive (left by previous owner) (Irish Music)------this removed------unit put back together--------still showing CD error------The CD side appears to be dead-------did not see any internal fuses in the machanical side of the unit-------did not know how to reset the thing-----I thought it would do this on powering up. it didn't------ appeared dead--------Are there any fuses in the display side of the unit------- I did not take the plastic facia off-------I did not know how to remove the on/off volume switch-----or the other telephone/ rocker switch------are there any codes to reset the thing.----------only the radio works------the next job I suppose is to test all the circuits for breaks--------and open up the display unit------any ideas------thanx for reading, ----came in the house rather stressed put on the Irish Music did it relax be, what do you think ?
dibs.
dibs.
