Sponsored by: Innova
Help !! NO sound from my new Sony CD player !! Help
Old May 15, 2003 | 01:45 AM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
Hi All,
I got a 1997 E420 and today I install a new Sony CD player CDX-M800 with VW's harness. everything looks fine, so power is not the problem, the AM/FM radio is function normally, but when I switch to CD, NO Sound at all !! I go back to the store I got the CD player from, the guy give me a demo one to try it, Still NO sound !!, so the CD player is ok, but how come is NO sound ? I have a stock Bose system, and I only install the CD play, the rest of the system are still stock ! Any answer to this problem ? I double check the harness wiring. everything is fine ! HELP !!
Old May 24, 2003 | 01:22 PM
whiteyford's Avatar
check and see if that particular car has a built in stock amplifier. This could be why there's no sound. You may need to bypass it.
Old May 24, 2003 | 01:30 PM
Horst's Avatar
e320 my2001
could it be that your new head unit has two trigger lines, one for antenna and one for sound amplifier? Where the amplifier trigger is always 12 Volt when the head unit is turned on, the antenna trigger turns off when you play a CD!?
