Sponsored by: Innova
2000 E240 auxillary in??
Old May 16, 2011 | 10:58 AM
anthonycutajar's Avatar
2000 E240 Elegance
Hi there
I have searched and searched and searched this forum for a while now looking for this information but i cannot find it anywhere!
Basicly i have an E240 w210 with COMMAND but NO aux in option in the glovebox. However my COMMAND unit lists aux as in option. Where do i find the input jack? as mentioned it is NOT in the glovebox. Is there a cable that has to be plugged into the back of the HU or something?? PLease help i hate the radio! and dont want to install a new headunit it so lovely how it is!!
Thanks in advance
Old May 16, 2011 | 11:17 AM
Diesel Benz's Avatar
Originally Posted by anthonycutajar
Hi there
Thanks in advance
If you do not find the AUX connector, you can retrofit a cable, attached to the rear of COMAND. Pin assignments should be 4 (L), 13 (R), 5 GND, 14 (GND and shield, connected to 13 at the X39 connector, for a 3 pin cable the ground wire can be connected to both).
