Sponsored by: Innova
EURO COMMAND PROBLEM
Old Jul 12, 2011 | 01:18 AM
CLS_724's Avatar
MERC
Question EURO COMMAND PROBLEM
Hi,
So I installed one of these Euro Command's in my CLS500 2006. Powers up and shows the Mercedes symbol but that is all it does?
The changer doesn't work either .. can anyone please help I'm leaving town tomorrow evening to Vegas and wanted to use this thing!?
Bought the item from an EBAY seller that has sold a more then a few and all his feedback has been good.
Thanks!
Old Jul 12, 2011 | 02:48 AM
CLS_724's Avatar
MERC
Oh I also removed the factory DVD nav drive if that could of caused the problem.
Old Jul 12, 2011 | 03:16 AM
Diesel Benz's Avatar
Why did you remove that Navi drive? If you disconnected the wires and reconnected the fibre ring, it should work but it sounds like you have an issue with the fibre ring and it could well be that you did not use a connector to connect the fibre when you removed the Navi processor.
Old Jul 12, 2011 | 12:51 PM
CLS_724's Avatar
MERC
You seem to be correct. I spoke with another member as well and he confirmed. I was doing some searching and I guess there is a plug I can buy at the dealer that will loop the un plugged portion with something on the audio gateway?
Any clue on how to do this? I'm so lost
As far as me removing the DVD nav drive I really do not use it. My plan was to put something else in its place!
Old Jul 12, 2011 | 02:59 PM
CLS_724's Avatar
MERC
Ended up just taking the car to the dealer and they have everything up and working in 30 mins. Thanks to those that had helped!
