Complete "renovation" of OEM stereo system
Old 08-10-2003, 12:23 AM
dragon's Avatar
CLK 350 convertible
This is another one located inches away from the first yellow clip
Attached Thumbnails Complete "renovation" of OEM stereo system-2ylowclip.jpg
Old 08-10-2003, 12:24 AM
dragon's Avatar
CLK 350 convertible
ppp
Old 08-10-2003, 12:26 AM
dragon's Avatar
CLK 350 convertible
Will post more picture when I am done.
Old 08-10-2003, 12:26 PM
dragon's Avatar
CLK 350 convertible
"Lizard" coming down from the HU and goes behind the foot-well. You must yank the carpet away from the firewall of the footwell.
File Type: bmp
Old 08-10-2003, 12:31 PM
dragon's Avatar
CLK 350 convertible
Pull those "lizard" from the HU and run it across behind the firewall of footwell and to continue further to the left side firewall.
File Type: bmp
Old 08-10-2003, 12:33 PM
dragon's Avatar
CLK 350 convertible
After the right side plastic cover is being removed.
Old 08-10-2003, 12:36 PM
  #32
dragon's Avatar
CLK 350 convertible
After your battery and aircon filter being removed
Old 08-10-2003, 12:39 PM
  #33
dragon's Avatar
CLK 350 convertible
This is another close-up of the square rubber with all the "slugs" and rember to pull one or more as required to insert "snakes" into it.
Old 08-10-2003, 12:43 PM
  #34
dragon's Avatar
CLK 350 convertible
This is the "modified" hanger which I did to pull the pwer wire down from the firewall.
Old 08-10-2003, 12:47 PM
  #35
dragon's Avatar
CLK 350 convertible
This is where I run the power/remote wires all the way back close to the right side. It is very easy to hide those "snake", simply use your magic finger and push it up the side molding.
Old 08-10-2003, 12:53 PM
  #36
dragon's Avatar
CLK 350 convertible
I hope that with this information, it will at least cut some cost for all the members, hope that it's easy to understand with the simpliest layman languages. If you do not understand what is written then probably you are too educated.
Dragon Baccarat System
Quick Reply: Complete "renovation" of OEM stereo system
