Sponsored by: Innova
iPhone connector does not fit with bumper on
Old Dec 12, 2011 | 05:04 PM
gnychis's Avatar
2001 E320 Sport
I had imagined someone had found a solution to this, but I did a bunch of searching through the forums and couldn't find strong discussion or a solution of this problem.
I recently purchased a 2012 C300 and I have an iPhone 4S with a standard Apple bumper. Whenever I try to connect the dock cable in the center glove box to the iPhone, the connector does not lock. Any slight movement will bump the cable out of the iPhone. It seems like the bumper is preventing this.
Has anyone found a replacement cable or some sort of adapter/extender that works for this without losing functionality?
Old Dec 12, 2011 | 10:24 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
I use a very thin, clear plastic case on my iPhone; the connector opening is large enough that there is no problem. It looks like the case in the photo below, although I no longer recall the brand. You might consider a different case rather than a different connector. Click the photo to enlarge.
Attached Thumbnails iPhone connector does not fit with bumper on-9539181_sa.jpg
Old Dec 13, 2011 | 02:52 PM
gnychis's Avatar
2001 E320 Sport
thanks for the feedback! ultimately, i would like to stick with the bumper. I did a lot of case shopping, and the bumper is exactly what i like.
Old Dec 14, 2011 | 11:43 AM
yozh's Avatar
GL450
You can always get a skinny adapter, or cut the bumper case a bit to make a wider opening.
Old Dec 14, 2011 | 12:04 PM
gnychis's Avatar
2001 E320 Sport
what adapter are you referring to? do you have a link?
Old Dec 14, 2011 | 12:07 PM
yozh's Avatar
GL450
I believe this should work,
http://www.dockextenders.com/shop-ip...apter-options/
OR THIS
http://www.buyijet.com/iphone-extend...tend-slim.html
Old Dec 14, 2011 | 02:24 PM
gnychis's Avatar
2001 E320 Sport
thanks for the response
I opted for an Amazon product, although slightly more expensive, I prefer the support of Amazon:
http://www.amazon.com/gp/product/B00...00_i00_details
I will post the results once I get it on Friday.
Old Dec 14, 2011 | 03:49 PM
yozh's Avatar
GL450
Looks like it should work. Let us know.
Old Dec 21, 2011 | 01:10 PM
gnychis's Avatar
2001 E320 Sport
worked out perfectly! no longer keeps easily popping out. worth it.
Old Dec 21, 2011 | 03:13 PM
yozh's Avatar
GL450
Glad to hear that!!!
