Sponsored by: Innova
Experiences with Tweeter?
Old Jun 24, 2003 | 10:37 AM
Hostile's Avatar
'99 E320
Has anyone had Tweeter do an audio install for them? If so what was your experience?
Old Jul 9, 2003 | 03:11 PM
WHEELRZ's Avatar
04 C 320/03 CLK 500
I have not had any problems with them. I had them do a custom box for me. check out the site on the bottom to see the box.
http://www.cardomain.com/member_page...=324098&page=2
Old Jul 16, 2005 | 09:49 AM
raunen's Avatar
2005 C320 4Matic
Anyone know how to release the speaker wires connecting to the tweeter? This is the connector with the square drawn around it in the attached picture.
Old Jul 16, 2005 | 10:47 AM
vraa's Avatar
Right below where it says six.
Or above where it says nine (depends on how you look at it)
You should be able to press in with a small taped screw driver to press in and release that clip.
Good luck, I might be wrong though.
Old Jul 18, 2005 | 12:52 AM
ChaRgeC230's Avatar
05 c230 SS
how did you the tweeter off? what car did it come off of.
Old Jul 18, 2005 | 09:00 AM
raunen's Avatar
2005 C320 4Matic
thanks ricky. i'll try that.
to remove the speaker grill, open the window, and pull off the edges (it has four clips attached to the door frame) then slide it toward the hood of the car. comes right off.
to remove the speaker (after disconnecting the wires), there are four tabs holding it in place onto the grill. pop all four from the inside out and pull the speaker out.
this is for an 05 c320 (and also tried it on a c230k).
