Sponsored by: Innova
COMAND/TV tuner wiring question
Old Jul 3, 2003 | 01:17 PM
MBS500C's Avatar
S500C, A190
I'm in the process of adding a TV-tuner, CANBus sim and CD changer to a 210 820 48 89 COMAND. I got almost all the wiring hooked up but am a little confused about the power and ground wires on the TV tuner and CANBus sim.
On the C1 connector, I currently have the CD power and ground wires hooked up to pin 05 and 06. Should both the CANBus sim and TV-tuner power wires be tapped there as well?? Would it "overload" the power supply?? Or should these power wires direct to ignition switch?
No one in my area has any experience with retrofitting COMAND, so I'm pretty much on my own Please help...
Thanks!!!!!!!!!!
Old Jul 3, 2003 | 01:46 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
C1 pin 5 and 6 are for the CD changer only...
The A connector that goes into the TV tuner with the power and ground wire need to be connected to a proper ground and (fused) power in your car.
greetingz,
