DIY crackling / rattling speaker fix (pics inside)
CLS55
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Had my CLS 8 months and lots has gone wrong so far (IC pump, dynamic seats, keyless entry etc....) and then recently my centre speaker would rattle at certain frequencies and volumes.
so I took it upon myself to fix something..
so here is what I did:
Pop grill off with credit card. allong the edge which is closest to you and unscrew 2 x torx screws (4mm hex key worked... just):
![](http://i995.photobucket.com/albums/af78/n13nhb/2012-07-17-156-1.jpg)
upon inspection of the speaker it was clear what the issue was:
![](http://i995.photobucket.com/albums/af78/n13nhb/2012-07-17-157.jpg)
Part information:
![](http://i995.photobucket.com/albums/af78/n13nhb/2012-07-17-158.jpg)
Once I had cleaned the old glue from under the cushion and off the cone I applied an even amount of PVA glue (seems semi flexible when dry)
![](http://i995.photobucket.com/albums/af78/n13nhb/2012-07-17-159.jpg)
Leave to dry (24 hours preferably (12 seemed ok)) and the annoying noise has gone.
hope this helps somebody... would have helped me...
*car info: cls55 hk sound system and parktronic)
Part information:
