AFTERMARKET AMPS and AUX IN PROBLEM SOLVED!!
This is for All MERCEDES WITH COMMAND AND D-28 OPTICAL PROTOCAL....(this is the little fiberoptic bus that all nav, phone, and audio travel on)
I have found the solution...WOOHOOO>>>>
http://216.239.39.104/translate_c?hl...os.html&prev=/ search%3Fq%3Ddomino%2Bmercedes%26hl%3Den%26lr%3D%2 <br />6ie%3DUTF-8%26oe%3DUTF-8
This is you
This is you again
this is me...
This is you
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
This is you again
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Cool. How do we get one?
I wonder how well it will work in a benz.
CREOS DMC6 Bedienungsanleitung Deutsch
CREOS DMC6 User’s Manual english
The CREOS DMC6 extends the functionality of your audio system in the vehicle, by it from the four-channel signal of your controller (for his part different sources to show knows, like CD, CD change-over switch, cartridge, FM/TO radio, TV sound etc..) and a common six-channel signal forms, which is then supplied to the achievement amplifiers for the six-channel signal of a DVD Multikanaldecoders.
In addition the CREOS DMC6 possesses an interface to a navigation system and/or up to two telephones. It is able to mute-connect your audio system in the case of a telephone call or a navigation announcement and to show the clay/tone of the navigation system and the telephones over the main loudspeakers of your audio system.
The CREOS DMC6 is operated by remote control by the controller. In order to obtain optimal sound quality, the CREOS DMC6 is connected by an optical D2B-Ring with the controller. This technology uses fiber-optic cables, in order to transmit the audio signal digitally. With the CREOS DMC6 the DVD Hoervergnuegen introduction holds into your vehicle. Please you remember that the DVD rendition can divert you from driving. Please you always stop therefore the volume to an appropriately low value.
![](http://www.domino-design.de/assets/images/creos_dmc6.jpg)
