Sponsored by: Innova
ipod integration and bluetooth phone
Old Jan 8, 2013 | 09:19 AM
murs11's Avatar
I have fitted a MB bluetooth pod to my 2007 CLK and my phone pairs and connects perfectly. I have also fitted a MB ipod integration kit to the Audio 20 which also works perfectly. Unfortunately, since fitting the ipod kit, the phone is still paired and connected but the display says NO PHONE. Could I have disturbed some connection during the fitting? I would appreciate any help with this problem.
Old Jan 12, 2013 | 03:29 PM
bfisher's Avatar
2008 E320
Mine only does this when the bluetooth didn't reconnect properly. Did you try turning off bluetooth on the phone and restarting it? Sometimes after this I need to select the MB choice in the available bluetooth choices.
Old Jan 12, 2013 | 04:17 PM
murs11's Avatar
ipod integration and phone
Thank you for your reply. I have indeed tried what you suggest but with no success. The procedure I follow is this. Starting from scratch, I make the phone visible, I press the button on the pod in the console to start the bluetooth searching. The phone is found and I enter 62872 when required. The phone says PAIRING, then CONNECTED. The phone asks if I want to download the phonebook. I reply yes but the Audio 20 and the dashboard display continue to say NO PHONE.
