Sponsored by: Innova
is it possible to...
Old Aug 6, 2003 | 02:16 AM
pointman's Avatar
a car that can't do the throttle reset.
Hey fellas... another question... i have a 97 c36...and i really really really want to install a comand system from a 01 s500... possible?!?
Old Aug 6, 2003 | 04:35 AM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Yes, I think so. Check out mercedesmods.com
Old Aug 6, 2003 | 04:41 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: is it possible to...
Why do you want one from an S500? The faceplate is a bit funny shaped, and it might be too big for the dash...
-s-
Old Aug 7, 2003 | 12:01 AM
pointman's Avatar
cuz... have an opportunity to get one at a great price.
Old Aug 7, 2003 | 02:55 AM
scorchie's Avatar
That great price will quickly be eroded by the money/time you will need to spend getting it fit into the dash.
-s-
Old Aug 7, 2003 | 03:22 AM
pointman's Avatar
im not gonna do it myself... i have a great install guy... and i can handle the price.
Old Aug 7, 2003 | 03:13 PM
scorchie's Avatar
If you can handle the price, why not get a COMAND that works better in your car then?
Otherwise, this guy is going to have to be real skilled with fabrication of wood dash trim and plastic dash supports.
Or if you are just waiting for someone to say "go for it" (it appears you are since every reason not to do it is "not an issue")...
I say just go for it!
-s-
Old Aug 7, 2003 | 06:10 PM
JohnAMG's Avatar
3 Porsche rotation
Personally I think the E/CLK class COMAND ergonomically suite your car better than the S-class Comand. It is too wide for your center console and you will end up butchering your interior I have personally retrofitted 2 COMANDs in my cars and couldn't be happier. I could of got S-class Comand, they are available on Ebay for about $700-800, I stick with what work even the price is slightly higher. If you have already made up your mind like Scrochie said, then good luck.
John
Old Aug 8, 2003 | 10:01 PM
pointman's Avatar
my question isnt if you guys think i should try it...my question is will it work in my car since my car isnt fiber optic...
Old Aug 8, 2003 | 10:12 PM
EH MG's Avatar
also, can this be done?
I've been asked by newer C-Class owners (240s/320s) if they can get the nav screen put in after they opted not to for their delivery. I've seen nav screens in c-classes from factory so I know its possible, but I hear they have to go aftermarket if they didn't order as option.
Valid question?
Old Aug 8, 2003 | 10:19 PM
scorchie's Avatar
If that was your question, why didn't you ask in the beginning?
Fibre optic has nothing to do with the car. It's part of the telematics system. You can add fibre optic to any car, you just run the fibre optic cables. You could run fibre optic in a Model T if you wanted to. Put the COMAND in the front of the Model T, run the fibre optic cables back to the CD changer in the back, it's all good!
So if that's all that's stopping you, get moving! We want pictures when you're done.
Oh, there's part numbers in the forums here for the fibre optic cable harnesses. Just do a search... this will make it a lot easier because the parts guys won't really know what you need.
-s-
Old Aug 8, 2003 | 10:20 PM
scorchie's Avatar
Re: also, can this be done?
Valid question?
Do a search on "COMAND" or "steve COMAND" and read the posts... all your questions will be answered.
-s-
Old Aug 9, 2003 | 02:27 AM
pointman's Avatar
Cool! thanks alot fellas... seeriously though... i am really impressed by everything you guys know...impressive.
