Replacing window antenna with mast?
My car is a 2006 CL 230 coupe -- which I bought around 3 moths ago directly from a MB Dealer - with a full 90 day warranty and all is fine other then -------
It's key (FOB) seems to be possessed - it sometimes works fine and sometimes not - my FM radio reception is also poor -- I have taken it to the dealer on two occasions but when there it works great even from a fair distance ---- I have read several posts which point the problem to the embedded antenna in the rear hatch -- and yes the glass was tinted which I removed in an effort to solve this problem, and the key batteries are new. I am wondering if the problem may be solved if I just install a mast antenna? I know that my radio reception would improve but not sure if it would work with the FOB. Any suggestions will be appreciated.
http://www.benzworld.org/forums/w203...pe-plus-3.html
Unrelated to the antenna thing -- I think that if too many tabs from the rear window plastic panels break one could carefully drill holes where the tabs used to be and use neat little screws - screwed into the metal clips.
