Sponsored by: Innova
Need help
Old Apr 1, 2013 | 08:41 AM
Lam JayPezzy's Avatar
Need help
I have a 02 c240 I removed the stock radio and I want to install a new aftermarket radio I bought everything the wiring harness and fiber optic cable and the indash kit but now I am stuck I there are 3 plugs that went to the factory but the new wiring harness has 2 slots what do I have to do? to get it to work .
Old Apr 1, 2013 | 10:38 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
You will have to find a wiring diagram of the OEM head and cut the pigtail off. Cut it so it can be reattached or resold.
Match the cables to the new head pigtail. If you are talking about fiber connections, you might have to get tech support from the new radio mfg.
Cheers, Gator
Old Apr 2, 2013 | 07:28 PM
thanks
do you mean i have to cut the stock pigtails and wire it straight to the radio?
Cheers, Gator
Old Apr 2, 2013 | 07:36 PM
Where is the best place on to ground the radio
Old Apr 3, 2013 | 10:43 AM
Chief Wiggum's Avatar
E320
Maybe this will help.
File Type: pdf
Old Apr 3, 2013 | 07:18 PM
do i have to splice into the actual mercedes wire though
Old Apr 4, 2013 | 10:24 AM
E320
Which wiring harness did you purchase? Was it a Metra 70-1784?
Old Apr 4, 2013 | 06:49 PM
YEAH the one they had at autotoys.com
Old Apr 5, 2013 | 10:35 AM
E320
As long as you have the Metra 70-1784 (harness), Metra 40-VW10 (antenna adapter), and Metra dash kit, then you're all set. You wont have to do any cutting and splicing, as the Metra harness and radio harness match color to color.
Old Apr 8, 2013 | 11:39 AM
hey chief i cant figure why my car aint powering up the radio
Old Apr 8, 2013 | 04:29 PM
GatorMB's Avatar
Thank's Chief,
I visited instology some time ago looking for radio info. but it turned out to be a fuse. I fixed my right side door control system today and found yet another fuse box. 4 on this car so far.
fuses are our friend.
Ground cables for audio amplified systems should remain 1 foot or less. for the head find a metal part on the dash and use a good fastener.
Cheers, Gator
