Sponsored by: Innova
REALLY APPRECIATE A LITTLE HELP.
Old May 22, 2013 | 01:28 AM
Leutrim's Avatar
Clk55
Hi, does anyone on here know if i remove my rear sam module and reinstall it if i have to reprogram it at a mercedes dealership? i took it out because it looked like it had a lot of corrosion on it and cleaned it off. didnt so much as to scratch anything inside of it and didnt use any chemicals. when i reinstalled it, the digital gas gauge will not work, the turn signals dont work, and the rear windows dont go up or down but the front ones work fine.. its a little weird but any help would be appreciated.
car is 2005 clk55 amg with command ii
Old May 22, 2013 | 10:48 AM
Leutrim's Avatar
Clk55
anyone?
Old May 22, 2013 | 04:03 PM
Leutrim's Avatar
Clk55
bump
Old May 23, 2013 | 01:55 AM
Diesel Benz's Avatar
If you just removed it (battery first disconnected) and reinstalled it (reconnected the battery), the SAM would not need programming.
Did you check all fuses, pre-fuses too? Did you check if all control units have power?
Is it a coupe or cabriolet? The wiring is quite different for the two.
Old May 23, 2013 | 12:29 PM
Leutrim's Avatar
Clk55
Thanks for the reply, and it is coupe. here is what i did exactly i disconnected the battery then took out the sam with fuses still on fusebox then disconnected fusebox wiring. then i took out the fuses and resistors which were all good i checked them because of the burn marks i saw. put everything back together including fuses and put the wiring back in the sam connected the battery and turned on the car. but as soon as i turned it on the warning came up saying display malfunction, drive to workshop.
