09 NTG 2.5 retrofit on 07 ML350 completed...sort of, need help.
NTG 2.5 (A1648707194 - no anti-theft codes pre09 (08/07/29), i guess?!)
HK Amp (A2519007300)
Sub Amp (A2118705189)
Used the attached wiring diagram wire the main amp.
Sub wiring loom http://www.kabeldaviko.de/product_in...s-ntg-2-5.html
Bluetooth antenna http://www.kabeldaviko.de/product_in...r-ntg-2-5.html
Mic extension cable http://www.kabeldaviko.de/product_in...e-ntg-2-5.html
Antenna Splitter http://www.kabeldaviko.de/product_in...a-y-cable.html
Got it all connected and it sounds great, yes i have sound.
NAV works (after getting gps splitter from dealer)
Sirius Radio works kinda, i get "No Service" it plays music (Hits1) but i cant change channels, this may be due to the Sirius module not being compatible with the NTG2.5.
DVD works
SD works
Phone works
Lingtronics works
Music Register works, although 4GB is not enough...
Radio FM/AM does not work, the comand says "Device Unavailable"...
on the Mic extension cable there was a Blue cable (pin 7-12V output) that is supposed to connect to pin 13 on the Quadlock, so i removed cable 13 from quadlock and jumped it with the blue cable hoping that my problem was the antenna amplifier not getting power but im still getting "Device Unavailable".Im at a loss as to why this is happening and im reaching out for help, any assistance would be greatly appreciated.
thank you
